View Full Version : Dead Machine bizhub 751 Dead Finisher
MFPs R Now PCs
06-22-2015, 10:17 PM
We have a bizhub 751 with a finisher on it that has been running fine for a long time. Just recently the finisher appears to be dead. The machine operation panel does not respond with indication when the finisher door is opened. During Boot-Up the finisher does not run ANY motors, paddles or rollers. The machine will boot all of the way up and make a copy, however it just jams upon entry of the finisher with no codes (other than jam). There IS 24 volt and 5 volt going to the finisher. Any thoughts? Thanks in advance!
SAR
08-07-2015, 01:57 PM
I have 2 of these finishers doing this! I was hoping you found out what the issue was on yours and might be able to tell me something.
Thanks!
tech51
08-07-2015, 03:37 PM
I had one do this. It turned out the firmware had gone from the fns control board. I re loaded the fns firmware and it was fine afterwards.
allan
08-07-2015, 03:39 PM
Are u sure those connectors between the machine and finisher is ok. It's easy to mess them up by disconnecting and pulling the finisher away. I have done that before.
I would do a point to point test on the connectors.
Next would be to look for ICP's then to swop the control board.
There should be a lot of unused machines around. I swop out and scrap the entire finisher if it gives trouble.
It could be on the machine side as well.
MFPs R Now PCs
08-07-2015, 06:57 PM
We have replaced the PWB Board for the punch unit and everything was fine for a week and then the same thing occurred. So we disconnected the punch unit permanently and discussed with customer for costs associated of replacing finisher, geez...:confused: THANK YOU TO EVERYONE!
