darkrune337
05-25-2008, 09:59 AM
Hello there! I have a problem with konica 7033, It produces what i can say is smudge copy or ghosting copy. It appears when i newly turn on the machine, but when the machine is warm-up for a long time the copy becomes ok. It happens when it is not yet so warm.
i tried to copy a scan image or built-in test pattern same result, it seems the copy is smudge or elongated. i jammed the machine before the paper enters the fixing area to isolate the problem. The problem happens before it enters the fuser area , so fixing is not the problem.
I suspect the drum is the problem but i dont have no spare to test it.
I suspect the drum because when i try to roll the paper round, the smudge or elongated copy matches the circumference of the drum where the problem copy is.
Anybody have encountered the problem ?
