View Full Version : Miscellaneous develop +224 printing issue
the doc
08-04-2015, 12:10 PM
Hi Folks
I have a develop +224 which won't print from a mac.
The machine has account track enabled and all windows machines print fine to it.The mac is running 10.10 and the correct driver has been installed however even though you put the account track code in the driver it still won't print,it does get to the machine but just says error when you go into the log.
any ideas would be greatly appreciated.
the doc
Gaffers01
08-04-2015, 05:36 PM
If you look at the Job list does it give you more info than just "ERROR" ?
emujo
08-04-2015, 05:47 PM
Just went through this with a 10.10 user a few days ago...The MFP was setup for password only and they were either putting user name and password, or entering the info in the wrong field. My 10.10.VM supports printing with account track and/or user authentication..BTW to use the latest mac drivers, the MFP has to be up to version 7. This requires both firmware and softswitch settings. Emujo
the doc
08-05-2015, 08:47 AM
That's Great emujo,do you know which soft switch by anychance.
Thanks for your help
The doc
emujo
08-05-2015, 04:05 PM
Latest firmware is K5, softswitch 25 should be at HEX 60 to support this version. Emujo
the doc
08-05-2015, 04:16 PM
Thank emujo,you could be a life saver.
Thanks again
the doc
emujo
08-05-2015, 04:22 PM
I hope so, but keep in mind that you are working with the Ineo version of this MFP...I only deal with the actual KM product. I have heard that drivers and firmware are sometimes different than what I would see with the KM devices. Emujo
