View Full Version : Bizhub 600 will not print? Question
Jag_97470
08-08-2015, 02:14 AM
Hello everyone, strange problem; This copier has never printed, customer only copied, copier only at 150K. Customer moved copier to another office that they now want to print. All network settings seem ok, so I hooked up laptop to test. From laptop as seen from PC I can ping ok, can access UI ok, but it will not print! no data light ever comes on. I did notice there are tabs missing, for example; no tab for configuration printout, no Printer tab! You can view all IP setting and network is turned on. Another tech I called seems to remember a small 4 pin print eprom on the main board? I don't know if this is true. Just wanted to run this by you guys and what do you think? Thanks guys!
iceman490
08-08-2015, 04:29 AM
I cant recall the model number for the eprom chip but the 600 750/601 751 does require an eprom chip to print
Jag_97470
08-08-2015, 05:03 AM
Thank you sir; Do you know if this was an option or came standard on the board? Just wondering if it is standard maybe the chip is corrupt. It sounds like to me it must of been an option. Thank you again for the reply.
iceman490
08-08-2015, 01:33 PM
The print eprom was optional
blackcat4866
08-08-2015, 04:24 PM
If you can still find it, it's called an IC202 PCL/PS image controller
You can get this sort of information from the brochure, like this: http://www.clinesbe.com/brochures/bizhub%20600.pdf
Jag_97470
08-08-2015, 05:31 PM
Awesome! Thank you guys for your time.
fixthecopier
08-08-2015, 05:50 PM
When it was new that chip was around $2500. I sold one to a customer.
