View Full Version : KM Di2510f Error C05000
gunterf
06-04-2008, 03:52 AM
What should I look for with error code c05000?
laserman06
06-04-2008, 04:27 AM
Warning--Be advised that with fuser codes, some risks are involved, please seek professional help to help reduce these risks. I assume no responsibility for improper use of the the following advice.
The C0500 code is a fuser failure to warm up(main). I have included a pdf file with what to look for.
How to reset a C0500 code.
Solution
The C0500 code can be reset following the steps below:
1. Press the soft initialization on the right side of the control panel.
2. When the dot appears on the LCD after reboot, press the number 3 key.
3. The mode will change to the initialization screen.
4. Choose the selection for trouble reset.
5. After reboot the code will be cleared.
gunterf
06-04-2008, 05:03 AM
Thank you for the quick response, Excellent info, makes sense given that the machine worked fine one day then showed error code for fuser the next day. Where can I find information for references made in the pdf instructions?
