View Full Version : Error Code code : c-3726 after replacing fusing unit with old one ineo 454
hugohug
10-19-2015, 04:46 PM
i have two machines ineo 454 one of them starts jamming a lot in fusing section ,
i cleaned the fusing unit
and i exchanged the two machines fusing unit
it worked fine at first after two days one of the machines starts giving me this code c- 3726
i removed fusing unit conections and power on the machine still the same code :confused:
thank you for any suggetions :)
allan
10-20-2015, 05:46 AM
Do a trouble reset.
hugohug
10-20-2015, 10:18 AM
Do a trouble reset.
thank you sir
can i ask how i can perform this trouble reset ?
laitang
10-20-2015, 12:20 PM
thank you sir
Procedure
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Reset key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
