View Full Version : Risograph error c23
kaiviti
06-17-2008, 09:15 PM
Hi,
I have this model risograph CR1610 which comes up with this error C23, is there any way i could clear this error and please could someone tell where i could find the manuals for this model so i can download it.
Thanks heaps
risografist
06-18-2008, 01:43 PM
Users manual: http://risografist.3dn.ru/manuals/CR_User_Guide_en.pdf
risografist
C23 Master Cut Malfunction
• If the Master positioning sensor is still detecting the master (light
reflected back) when the Drum is at position-A after the cutting
operation and the Master tentioning plate sensor is ON.
• If the Master sensor detects the master on the Drum again just
after 'C23' error is cleared, 'C23' will be displayed again.
Resetting Method:
Drum Set Sensor OFF & 5 seconds later ON while Master Positioning Sensor is OFF.
kaiviti
06-23-2008, 03:31 AM
thanks again for you help, i have check the loading plate and found it tobe missing a screw on the left side,everytime it goes down its hard for it to go up again then creating the error C23.
malo aupito again
