View Full Version : BizHub C654e Printing issue
halbrandenburg
02-11-2016, 02:45 PM
Customer is reporting that occasionally, when the copier runs out of paper during a print job, once paper is replaced, the job will not resume printing. Anyone else run into this and have a solution? Thanks in advance.
copier tech
02-15-2016, 06:06 PM
I had this before, I told the customer to be paitent as there is a bit of a delay while the tray lifts etc. I also updated the firmware & set to function version 7
Never heard back after a few months so assume that fixed it.
blackcat4866
02-15-2016, 11:11 PM
You might also go to tray settings, and change Auto Tray Switching from Restrict to Allow, then select some trays to auto switch. =^..^=
copier tech
02-16-2016, 08:43 AM
Yeah tray setting auto switch is a good point, but if that's not set i'd expect it to happen every time the paper runs out.
