View Full Version : Miscellaneous Bizhub C308
Peter Pring
02-17-2016, 03:20 PM
I have a Bizhub C308 (installed 15 days ago) customer places A4 original on platen glass and presses for one copy, machine screen shows SCANNING STOPPED and LOAD NEXT ORIGINAL or FINISH, as if separate scan is set to on, but this is set to OFF. the machine is running on the latest firmware GOO-84. any advise would help. all other functions i.e. print, doc feeder all working OK.:confused:
tekhed
07-13-2016, 05:38 AM
utility>User Settings>System Settings>Separate Scan From Platen?
copier tech
07-13-2016, 08:37 AM
Poster states this is set to OFF
Have you tried turning separate platen scan on, rebooting, trying a copy, then turn separate scan off again?
Also try setting the user setting back to factory default.
kingarthur
07-13-2016, 10:08 AM
Is "finish" default set to "sort" or "auto", think if it's set to "sort", it'll wait for another original to "sort"
tekhed
07-13-2016, 01:06 PM
Poster stated it was off, off in application settings> original settings> seperate scan, or off where I suggested? This was not specified....
Woxner
07-15-2016, 03:39 AM
it will ask for next orignal if sort mode is on. same if sep scan is on. some idiots set these to sort mode but they auto default to sort if more then one orignal and more then one copy
