MDR24
02-22-2016, 10:26 AM
Hi all,
Having an issue with an Ineo+224. When you try to use the USB instead of coming up with the scanning options (save/send to external device) the machine will pop up with "this function is unavailable". It was working and being used regularly and according to customer one day just came up with this message.
Things we've tried
Plugging it directly to the board to bypass the USB umbilical.
Formatted the USB FAT32 (which works on other machines in the building both +224's)
Firmware up to date and re-installed.
The settings in admin mode to enable external devices is set.
The USB works if you go through the user box settings and select scan to/ scan from external device.
Thanks in advance.
Things we've tried
Thanks in advance.
