View Full Version : Bizhub C224e ghost image
photocopier.technician
03-09-2016, 07:48 PM
Hi
I am having a problem with a Bizhub C224e. When printing there is a part of the print that repeats itself on the page. As per experience i thought it was the fusing unit but when i stopped the print before it gets into the fusing unit the problem is already there and also the fusing unit rollers are clean. So its not the fusing unit.
Then i checked the drum units all of them seem ok. Even tried to swap cyan with magenta but still same problem. When i removed the transfer belt just after a copy i can see the repeated image on the transfer belt.
Cleaned the lasers and the drum corona
No error codes or warnings
I attached a sample for better understanding the problem.
Please give me your opinion
Max
03-12-2016, 10:12 AM
Try the belt 1st. looks like its not being cleaned
EarthKmTech
03-12-2016, 10:33 AM
all 4 erase lamps working properly ? Drum grounding check out ok ?
that repetitive image defect is drum spacing.
Possible run away HV control issue too / defective hv board.
yianni
03-13-2016, 04:55 AM
I've never seen repeating white text. Try printing another pattern. For example fill 50% of a color and inside it black, white, cyan, magenta and yellow text.
allan
03-13-2016, 10:24 AM
Is the paper printed LEF or SEF? long side first or short side first.
Do you get this defect from the demo page??
Synthohol
03-13-2016, 11:20 PM
are the erase LEDs working?
adecanmin
03-14-2016, 12:04 AM
I had this exact problem. Tried replacing everything mentioned. What fixed it for me was using a different driver. They were using a PCL driver, printing from an Adobe program on an XP box. I tried an PS driver and the problem was fixed. What's strange is the machine worked fine for a year and half with no issues with the previous driver.
