View Full Version : Jamming FS-535 J72-13
captain
05-19-2016, 02:42 PM
FS-535 running on a C754e
Random jams occurring with a J72-13 code and paper always stops in the same spot. It seems to be getting caught on just the center tooth of the gate that is called part /5 in the paper transport section of the parts manual.
It will only do this when the paper runs long side first but short side first it will never miss a beat.
Thank you for your help in advance!
captain
05-24-2016, 08:14 PM
I apologize I meant the part in the parts manual is listed as "Part /2" in the parts manual...
Synthohol
05-24-2016, 09:58 PM
seen this a dozen times, the spring broke on the solenoid that controls the gate.
i attached the bulletin and i will tell ya, if you have 2 spring hook tools you can just change the pintle and spring and leave the solenoid screwed in. sooo much easier. also pop the whole top off the finisher to get access.
33004
splblazer91
05-25-2016, 02:28 AM
I use a spring hook and an extendable magnet to guide it into place haha. forget taking all that stuff off.
Synthohol
05-25-2016, 12:00 PM
do you hum the theme song from Mission Impossible while replacing it too? :)
Rikk811
10-06-2016, 06:27 PM
I know that this is an old thread, but I stumbled across it. That bulletin is for 72-19, that applies to 72-13 as well?
CompyTech
10-06-2016, 08:57 PM
72-13 shows the Zfold entrance sensor as the area. Check the solenoid springs anyways, cause even if they're the updated spring they can still fall off the gate.
MVPunisher
11-01-2017, 03:03 PM
What did you ever establish with this machine? All springs and gates seem to be in tact and operating as normal....
