View Full Version : CQ ibizhub 920 pro
samirelg01
05-30-2016, 06:19 PM
i early bay ibizhub 920 pro and i contacted one problem and i didn't resourd it.he give me a copy very unclear on A4 and little clear on A3.i try with all piece :cylindre,coron,developor , tonner ;in system but i don't arrived to a solution ...... please if there a possibility please help me.....i waiting for the answer
allan
05-30-2016, 07:57 PM
Stop the machine in the middle of a copy. Is the image on the cylindre clear or not?
Transfer could be one problem.
samirelg01
05-30-2016, 08:21 PM
i do it .the copy is not clear
allan
05-31-2016, 12:28 AM
Make sure that the drum is earthed. Make sure the Development unit bias makes contact.
Mick01
05-31-2016, 02:40 AM
Hi,
Are you referring to copying off the glass or printing via PC?
If copying I would start by cleaning your optics. When the mirrors get dusty it lightens the image. It performs a white refernce check when it is powered on to adjust this.
If printing is the issue and you have confirmed the image is light on the drum then the suggestions from the previous post need to be checked.
samirelg01
06-01-2016, 04:10 PM
i'm printing via pc it's the same copy.and i changed the drum the developement but i don't get the clear copy ..... i think the problem is coming in system or cards electrinics ..
Synthohol
06-01-2016, 08:05 PM
sounds just out of focus, have you cleaned the dust proof glass above the drum in the main body?
also maybe the printhead bumped out of position in its travel to you.you may want to take off the side panels and reseat the printhead
blackcat4866
06-02-2016, 01:17 AM
A sample of your problem would be very helpful. =^..^=
samirelg01
06-02-2016, 09:57 PM
i clean the glass but not thing for this time
i want to change the cards but which of them control the copy
or some problem in the system copy
