View Full Version : C451 - color problem with feeder copy
pat
07-01-2008, 08:16 PM
Hi,
I have a color problem but only if i copy trough the feeder (df 611).
I printed the demo page which is good, when I copy it from the copyboard it's good but when I copy the same original with the feeder it's much lighter and some grey squares have a light orange color.
First I checked the feeder position wich was ok
I ran trough the feeder setup a few times with the same result
Also I tried to range the RGB color setting for the feeder but it's still no good.
any ideas?
laserman06
07-02-2008, 12:31 AM
Go into tech rep mode and run stabilizer in initalization mode. Then run gradation. Make sure all optics are clean.
pat
07-02-2008, 05:13 PM
I tried that already and the copies made from the copyboard are fine so I wouldn't think it has anything to do with that, not?
laserman06
07-02-2008, 11:03 PM
I saw the following on Konica's site:
Products Products:
bizhub C650
bizhub C550
bizhub C451
Options:
DF-611
Details Subject:
DF-611, copies of originals fed through the RADF are light. Copies of originals placed on the glass are OK.
Description:
Solution:
CAUSE: The machine memory is scrambled.
SOLUTION: Reset the machine to factory defaults by performing the following:
1. Press the Utility key.
2. Press User Settings.
3. Press Copier Settings.
4. Press Default Copier Settings.
5. Press Factory and OK.
Details Subject:
DF-611, copies are wavy and exhibit poor copy quality from the document feeder. Copies of originals placed on the glass are OK.
Description:
DF-611, copies of originals fed through the RADF are wavy and exhibit poor copy quality. Copies of originals placed on the glass are OK.
Solution:
CAUSE: Incorrect document feeder height.
SOLUTION: Perform the RADF height adjustment as outlined in the Service Manual.
Frostwolf
07-03-2008, 09:43 PM
Documents run through the feeder are copied at 300 dpi, off the glass 600 dpi, that would account for some quality loss.
