wseyller
07-18-2016, 05:56 PM
Have a C258 that looses the ability for the card reader to work.
History: there used to be an issue where card reader would lock up after self association with Papercut.
This special firmware was loaded which help resolve the issue.
bizhub C368 Series [Special FW Ver.GG5-54] Failing to login using card reader
C308 C368 A7PU0Y0-F000-GG5-54.exe
Then it seemed that some card were not working well, so I moved the card reader to the outsite of copier and that seems to work because the users didn't place the card in the right spot I'm thinking.
Now they are saying that after a period of time possibly during or after the weekend the card reader will stop working. The light on the card reader will flash but nothing will happen. They reboot the copier and then it is ok for a while.
Have turned off sleep setting and set to go into low power mode as normal instead of immediately.
Loadable driver used
A7PU0Y0-A015-G00-03 AU-205H.exe
They have another in the building but it is used very little compared to this one.
Card reader was swapped out with another
