View Full Version : Bizhub 36 hdd full error
Intone
07-20-2016, 03:03 PM
machine is getting an hdd full error, reformatting hdd worked before but will not work anymore. did firmware about six months ago to fix other quirky problems. outside of replacing the hdd, any suggestions? thank you.
mo0651
07-20-2016, 10:43 PM
Is this happening when you are scanning?? What are the settings?
Intone
07-21-2016, 02:29 PM
it was happening when they were scanning
mo0651
07-21-2016, 02:31 PM
Check scan settings, are they scanning with "compact PDF"?? Set it to PDF.
Intone
07-21-2016, 02:44 PM
I will check that and report back. thank you.
Synthohol
07-21-2016, 04:23 PM
Why not try enabling hdd overwrite mode 1.
It will write 0x00 over the scanned data freeing up the space to be used again.
It will erase the addressbook initially so back up all the settings first.
deleuex
07-24-2016, 05:49 AM
I had the exact same service call I tried formatting the hdd, updating firmware etc and the suggested fix from Konica was exactly that which was switching to PDF (not compact) then setting it as default settings.
allan
07-24-2016, 07:43 AM
There is a special firmware fix out there for this same problem.
Not sure of the ver.
