View Full Version : Error Code FS519 C-1183
xdelios
07-21-2016, 08:04 AM
Hello,
I am experiencing a problem with a FS519 finisher on KM C253
This error code appeared in the past once again, I then searched the forums and found some reasons this could happening.
Honestly all I did is unscrew some things and re-screw them and it worked.
I put it back on yesterday.
Today I got the same problem.
The thing is it happened when I was about to get a page printed on the lower tray of the finisher. This was the case the first I got the error as well.
So the finisher starts moving up and it gets to the point it should and then stucks.
I know the lift motor isnt the problem cause I used it on another FS519 and it worked just fine.
I re-inserted the trays in case something was wrong there but still nothing.
Any ideas?
Regards,
George
habik
07-21-2016, 07:38 PM
Have you tried screwing in top tray properly or in different slot?!
Sent from my iDon't believe in marketing device using Tapatalk
xdelios
07-24-2016, 04:47 PM
Hello,
The plastic holders tha came with the finisher fit exactly is a specific spot from the right side. So changing the place of it aint an option.
