View Full Version : Error Code bizhub 282
fearless
07-23-2016, 04:43 AM
Hi Guys ,
HOW IS IT THAT MY COPIER BIZHUB 282 IS SHOWING ERROR after trying to update with special firmware for aborting the job.0x0000999.now it says FlashRom set up
ERASE PROGRAM OK
Error 0x0000e011
Imust have totally missed a step at the end of the week.
any idea is deeply appricated
Synthohol
07-23-2016, 12:39 PM
what was the exact firmware you used?
fearless
07-23-2016, 12:52 PM
Msc a11u-0100-g10-08-002
printer a11u-0050-g00-01-000
s#v012000630
Synthohol
07-23-2016, 01:02 PM
8/11/2009 19.59 MB A11U-0100-G10-08-002.zip (http://onyxftp.mykonicaminolta.com/DownloadFile/Download.ashx?fileversionid=5081&productid=1180)
Release Notes: 222, 282, 362 MSC Phase 2.0 Firmware Version 08
CAUTION: You CANNOT upgrade Phase 1.0 machines to Phase 2.0 level firmware
Phase 2 serial number cut in:
From "A11W011002051" onward => bizhub 222 Phase2
From "A11V011001338" onward => bizhub 282 Phase2
From "A11U011001706" onward => bizhub 362 Phase2
Serial numbers below are Phase 1 systems.
maybe thats the problem?
SEE DLBT0902293EN00.pdf for a list of enhancements
fearless
07-23-2016, 01:47 PM
Thanks for looking into this
These B&W machines are great until they run into these issues. i used 128 MB FLASH CARD (formatted in FAT ) and installed special firmware( A11U-0100-G07-09-002.exe) that kmbs recommend will be a fix for correction of Abort code(( 0x0000999 ) After extracting the file + copied it to the card,copier power was unpluged and the right door open ,i started the procedure.in very short time it gave that message ( erase program was ok ) with eror code ( 0x0000e11 ) As i tried to put the original firmware back on it , that is when i got the big ERROR in middle of the screen .
How do you update these machines?
Thanks a whole bunch
Synthohol
07-23-2016, 01:59 PM
why was the door opened? thats not procedure.
fearless
07-23-2016, 02:38 PM
I did follow the procedure for fininsher instead of MSC. Thanks for mentioning that.so do you think there is a chance to recover from error ?since this is a phase 1 machine what would be a grat fix for Abort code 0x0000999?
Thanks for all of your Help
Synthohol
07-23-2016, 02:52 PM
unplug the network cable and see if it boots up.
fearless
07-23-2016, 02:59 PM
Actually at this point it show ERROR .
Synthohol
07-23-2016, 03:03 PM
you can try base firmware?
fearless
07-23-2016, 03:07 PM
because the machine did erase the program ok there is no firmwre on it.I did turn it on to see if there is any luck.no luck
fearless
07-23-2016, 03:18 PM
https://us-mg204.mail.yahoo.com/ya/download?mid=2%5f0%5f0%5f1%5f7975802%5fABh3w0MAAOs uV5N4RQSbsK1d7Oc&m=YaDownload&pid=2&fid=Inbox&inline=1&appid=yahoomail
Synthohol
07-23-2016, 03:24 PM
try booting with base fw on the card.
fearless
07-23-2016, 03:44 PM
you mean with this firmware A11U-0100-G05-09-002 ? i will give it a try on monday.just in case if it was not recovered I am going to replace the MFBS2 Board FOR PHASE 1 MACHINE
Thanks a lot again V ersion PHASE_1_ONLY_G05-09Version PHASE_1_ONLY_G05-09
Synthohol
07-23-2016, 06:25 PM
double check your serial number to make sure you are 1 or 2 first.
