View Full Version : Colour Block Printing on C6501
resolute
07-27-2016, 12:31 AM
Every 10 Sheets I am getting these colour blocks that are printing. I am just printing on basic 8.5 x 11 paper.
Any suggestions on what is causing this. I just replaced the transfer belt and transfer roller. I get about 10 sheets - then a cyan and black patch print, then 10 sheets later a magenta and yellow patch print.
I going to pull the machine apart again tomorrow and see if I didn't put something back together properly -- cleaning unit comes to mind.... suggestions?33651
blackcat4866
07-27-2016, 12:35 AM
I would think that your primary transfer belt isn't cleaning very well. =^..^=
Woxner
07-27-2016, 05:12 AM
did you put the belt blade springs back on or prime the blade. those are the color registration squares
tulintron
08-01-2016, 09:01 PM
[QUOTE = resoluta; 526.037] A cada 10 Folhas estou recebendo esses blocos de cores que estão sendo impressos. Estou apenas a impressão em papel básico de 8,5 x 11.
Todas as sugestões sobre o que está causando isso. Acabei de substituir o rolo da correia de transferência e transferência. Recebo cerca de 10 folhas -., Em seguida, um ciano e impressão mancha negra, em seguida, 10 folhas posteriores a magenta e imprimir mancha amarela
que vai puxar a máquina para além de novo amanhã e ver se eu não colocar algo de novo juntos corretamente - unidade de limpeza vem à mente .... sugestões? 33651[/ QUOTE]
sent this picture, besides the blocks there are lines. these lines are also inappropriate or are the file?
I have a problem with lines after doing crazy with C6500.
