fixthecopier
07-27-2016, 08:52 PM
This is a long shot to describe a noise. For a few seconds during boot up, and when copies are made you can hear a rapid clicking noise that sounds like it is coming from the front right side. it sounds like below the control panel. If you remove the black toner, it sounds like it is on the other side of the wall, where the fuser preheat coil is located. So far I have...
Remove rear cover and checked fans.
Remove all toners
Swap waste toner box
Swap transfer belt
Tricked the right side door while booting... still made noise and sounded like it was behind fuser.
I just found another fuser I can swap. Will do tomorrow.The noise is very rapid, like a piece of paper in a fan blade. Any ideas?
Am I missing something? Can't find a load check in menus or service manual
Remove all toners
Swap transfer belt
