View Full Version : AirPrint on Bizhub C224 none E version
doinbox
07-27-2016, 10:30 PM
Is it possible to have AirPrint enabled on a C224 none E version. According to the bullitin it states it is available on C224 and also the E versions. If it is possible could someone explain what firmware I need to be on. As Far as I'm aware you upgrade to A9 then to K9 to turn the machine into an E version but I did this, changed the software switch to function 7 and when I apply the software switch for AirPrint it isn't saving. Any ideas. Thanks
Synthohol
07-27-2016, 11:03 PM
there is nothing bluetooth or wireless in the 4 series.
you need an EK-208 to enable this.
if the copier is on the same as their wireless network with the same IP scheme just download pagescope mobile and presto!
doinbox
07-27-2016, 11:09 PM
AirPrint on a 224e works through a device connected to the same network nothing to do with Bluetooth or wifi adapter.
copyrooks
It's not available with this model. If they need to print with iPhone go with pagescope mobile app.
doinbox
07-27-2016, 11:17 PM
No problem. Just baffled me how it mentioned both ranges on the bulletin. Thanks anyway
Woxner
07-28-2016, 01:51 AM
If you update the voice data to version 7 and turn a dip sw on it will show the air print if not mistaken. I just did the BH284 to do this.
Woxner
07-28-2016, 01:53 AM
could have been a 284e will have to check
