View Full Version : BH C1085 gives Jam Tray 3 Jam-1622
alamsandhu
08-07-2016, 01:21 PM
BH C1085 newly installed machine only 15K Prints gives Jam from Tray 2 J-1632 and Tray 3 J-1622.
Replaced Parts and Corrective Action...
1- Replaced suction belt drive clutches for all trays.
2-Cleaned the suction belts
3-Cleaned the Feed rollers and adjusted the pressure by using the paper.
but still the same
Any Idea
Regards
Synthohol
08-07-2016, 02:09 PM
is the PFU level?
1622: During operation: Within a specified period of time after the paper feed sensor/3 (PS10) becomes active, the loop sensor/Lw (PS17) does not become active.Only when the paper is fed from tray 3.
1632:
During operation: Within a specified period of time after the suction belt clutch/2 (CL16) becomes active, the paper feed sensor/2 (PS6) does not become active.
guides too tight against the paper?
alamsandhu
08-07-2016, 02:59 PM
[QUOTE=Synthohol;527398]is the PFU level?
1632:
Level is adjusted to correct position and Cleaned the Suction Belts,Belt Drive/Transport clutches, and swapped now working fine but last time after changing it works for 3 Days.
Haroldbfix
10-11-2016, 04:41 AM
Im seeing this issue as well. Did you get yours resolved?
Joecephus
03-15-2017, 09:47 PM
I'm having this issue as well on a brand new machine. what fixed your machines? thanks
Synthohol
03-15-2017, 10:42 PM
is the PFU level?
latest FW for everything?
