View Full Version : Error Code Konica Minolta C452 Error C3725
mearmi
09-06-2016, 04:39 AM
Konica Minolta C452 Error Code C3725
Replaced the fuser Unit but still getting C3725
Please advise
Thanks and Regards,
allan
09-06-2016, 05:00 AM
Could be the induction heater board or a door switch.
Had that once or twice.
mx6turbo89
09-06-2016, 05:09 AM
Please advise
Thanks and Regards,
You need to perform this procedure to get rid of that code:
B. Procedure
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and
check if the machine starts correctly.
mearmi
09-06-2016, 12:21 PM
B. Procedure
By resetting it disappears. But after couple of jobs it appears again
mearmi
09-06-2016, 12:22 PM
Right Side Door?
mx6turbo89
09-06-2016, 03:13 PM
C3725: Fusing abnormally high temperature detection (NC sensor)
Relevant parts:
Heating roller temperature sensor/1 (TEMS1)
Heating roller temperature sensor/2 (TEMS2)
Heating roller temperature sensor/3 (TEMS3)
IH power supply (IHPU)
Relay drive board (REDB)
Printer control board (PRCB)
Action:
1 Check the fusing unit for correct installation (whether it is secured in position).
2 Check the open/close operation of the upper right door.
3 Check the fusing unit, IHPU, MFPB and REDB for proper connection and correct or change as necessary.
4 Change TEMS1, TEMS2 or TEMS3 — —
5 Change fusing unit — —
6 Change IHPU — —
7 Change PRCB — —
8 Change REDB — —
mearmi
09-08-2016, 07:07 AM
Relevant parts:
Action:
6 Change IHPU — —
7 Change PRCB — —
8 Change REDB — —
Have changed door switch Prcb and new fuser
any my advise thanks
mx6turbo89
09-08-2016, 01:59 PM
Not much left at this point except the Induction Heating board (IHPU) as Allen suggested in the 2nd post.
mearmi
09-14-2016, 01:59 PM
After Replacing IHPU
now getting C3825
please advise
