View Full Version : C454e Error Code C3425
copierwhisper
09-16-2016, 11:44 PM
C454e with error code C3425, preform trouble reset after replacing the fuser unit and the code continues to return. According to the service manual relevant parts are fuser, DC Power Supply and PRCB. Replaced the DC Power Supply, could this really be the PRCB? The customer was running copies and noticed the toner was not fusing, it would wipe right off. Then it gave the trouble code...any thoughts?
Woxner
09-17-2016, 03:02 AM
there is a board that controls the fuser replace it. DCPU
copierwhisper
09-20-2016, 10:21 PM
I replaced the fuser, DC power supply and the PRCB...C3425 remains. Any thoughts? Initially the customer reported toner was smudging off the paper (not fusing) and then the machine threw an fuser error. Replaced the fuser, reset code and then the C3425 began.
FixStuff
09-21-2016, 04:58 AM
Can you run the machine at all? If you run it is the fuser warm? Maybe the coil unit, although I don't think I've ever replaced one on any machine.
copierwhisper
09-21-2016, 09:43 PM
The machine does not run at all. After resetting the trouble code and rebooting the machine the code comes up within the first few seconds of warm up.
Woxner
09-21-2016, 09:48 PM
replace the coil now that you did everything else
mx6turbo89
09-21-2016, 10:07 PM
Also check and clean the Heating Roller Temperature Sensor that's located under the coil.
Woxner
09-22-2016, 12:36 AM
he did replace the fuser
mx6turbo89
09-22-2016, 01:32 AM
The heat roller temp sensor isn't located in the fuser.
kosto
01-30-2018, 02:01 PM
If the problem is coil, how to fix it, there is another way to fix the coil
? All we must change it. Thx once again
joelea
01-30-2018, 04:03 PM
Procedure for changing the coil is in the service manual. Its a serious fire risk if you do it without previous experience or guided by the manual.
