View Full Version : BZ950 double-siding registration
Downunder
09-20-2016, 12:14 PM
Hi - I have a BZ950, 1.4 mil on the counter. Machine in good order.
Ok I have a double-sided original. On both sides there is a border 1 inch in from all sides. The borders align perfectly front and back
If I copy the one side of the original from the glass, registration is perfect. Can put the copy on top of the original and everything lines up perfectly.
If I copy the one side from the doc feeder the copy lines up perfectly with original
No here is the problem -- I select 2to2 and scan from the doc feeder the image is out on both side by about 5mill. and borders dont line up with each other
If i scan from the glass 1-2 manually I get the same effect as the doc feeder.
Hopefully this is clearly put out.
All rollers have been cleaned. copier runs perfectly single-sided. Latest firmware up to date.
Any carefully thought out suggestions would be greatly appreciated.
Synthohol
09-20-2016, 12:40 PM
isnt that 2nd side restart timing?
methogod
09-20-2016, 05:04 PM
with doc feeder you will always loose 5mm, best to copy from glass if you need 1 to 1 reproduction. You can adjust all the settings all day will never be as good as directly from the glass...
IMHO
