View Full Version : Miscellaneous Access C284e CE Mode remotely
copier tech
11-11-2016, 03:59 PM
Hi all,
Quick question, I need to change a few service mode settingswithout visiting site, is this possible? If so how should I go about it pls?
Thanks.
habik
11-14-2016, 02:58 PM
FTOMH
Remote to clients PC.
Login as admin to the MFP.
Set up new certificate.
Enable SSL
Enable Remote panel
Exit login as admin
Now log in via remote panel
Https://ip adress:50443/panel/top.html
Now navigate as if you are in front of machine.
Sometimes you may have to hit refresh to update the screen.
When you are finished ENSURE you EXIT and most importantly CLOSE the browser window. As sometimes the machines is still hooked and may hang in remote operation.
Byting on bits.
habik
11-16-2016, 08:40 PM
Did it work for you?
Byting on bits.
emujo
11-16-2016, 09:08 PM
FTOMH
Enable SSL
Enable Remote panel
Exit login as admin
Byting on bits.
You will only get the remote panel settings section if the CE password is enabled. And you want to turn on "remote panel client", not server. Emujo
copier tech
11-16-2016, 09:15 PM
Thanks for the info guys, i've not had a chance to try it yet
wseyller
11-18-2016, 11:57 PM
I tried it this morning because I never tried before. Had a demo unit with ssl already on. I turned the CE password to on. I turned on the Remote panel server to On and used the link Https://ip (https://ip/) adress:50443/panel/top.html
It worked pretty good.
Max
03-09-2017, 09:21 AM
Follow this. Works very well. http://www.copytechnet.com/forums/konica-minolta/113786-access-c284e-ce-mode-remotely.html
