View Full Version : c550
big jase
07-20-2008, 08:17 PM
i have a c550 ghosting a small smudge mark after text just on b/w copys..i have replaced iu ,transfer belt was replaced no 2 long ago, this does seem a intermitant problem:confused: can anyone help please
laserman06
07-20-2008, 10:21 PM
I am going to assume that this is doing it on both prints and copies. If you haven't try cleaning the print heads. I had one doing the same thing. Cleaning the print heads did the trick for me.
dogsbody
07-21-2008, 12:34 PM
i have had a smudgey mark after text on the 2nd side of a page. check the pdf at the address below. a quick check is to put some sticky tape just after the transfer roller, if your problem goes away you need the mod.
http://www.copytechnet.com/forums/konica-minolta/8060-c550-2nd-side-smudgy-marks-2.html
big jase
07-27-2008, 07:05 PM
thanks dogsbody did mod guide and replaced transfer roller,been ok since :):):):):):):):):)
Bizhub
07-27-2008, 08:02 PM
Yep that is the cure !!
If you do not have the guide mylar then electrical tape may get you out of a hole !!
dogsbody
07-31-2008, 09:22 AM
in the last week i had a C450 (not 451) do this to me. Regular sticky tape did the trick till i put a real one on.
Bizhub
07-31-2008, 07:55 PM
Take the blue resistor off from tbu sensor assy
