View Full Version : Status/Counter Notifications
dickierock
12-15-2016, 04:03 PM
Hi,
I have tried to set-up status/counter notifications on Bizhub C284 + C203 without success.
I have set-up machine on the network for scan to email function which is working fine.
I have checked in Email TX SMTP
E-mail TX Setting
Scan to E-mail
ON OFF
E-mail Notification
ON OFF
Total Counter Notification
ON OFF
and also have set-up in Maintenance Column
the Status Notification + Total Counter Notification email address setting.
However I do not receive the notifications after testing.
I must be missing something other settings?
Thanks for input.
kingarthur
12-15-2016, 04:47 PM
not all customers networks will allow these to send outside of their network, I normally pass it to the customers IT, and they sort it so the IP address is allowed to send out...
dickierock
12-15-2016, 05:04 PM
not all customers networks will allow these to send outside of their network, I normally pass it to the customers IT, and they sort it so the IP address is allowed to send out....
These are devices that are set-up in our own workshop and are using our own internal mail server.
It seems to me that I am missing a setting somewhere.
We don't normally monitor our devices this way but use software on a server/p.c. to do the monitoring, hence why I haven't set this up before.
I want to be able to use this function where the software is not working as it should for whatever reason.
Synthohol
12-16-2016, 04:35 AM
some mail servers will block anything that appears to be spam.
make sure the admin address is a known safe sender to the recipient
holy crap i spelled recipient correctly without word check
boink out the network settings in initialization and redo?
check/upgrade FW
change the copiers IP to something else
just some of the things i'd try myself.
habik
12-16-2016, 05:41 PM
can you scan to email?
Have you tried gmail setup?
device + admin email: gmail e-mail
SMTP TX SETTINGS
smpt.gmail.com
465
sender: gmail e-mail
authentication: ON
uid: same as sender
pswd: gmail acc pswd
mail.google.com
Synthohol
12-16-2016, 06:03 PM
He said it's an internal email server and it works for scan to email.
Try a different email to send to internal or external see if it was just the account it was trying to send to.
