View Full Version : Fused unit error
tivzualuke
12-16-2016, 09:58 AM
I have changed my fusing unit more than 3times but not working, still showing error. What can I do.
Sent from my Infinix HOT 4 using Tapatalk
allan
12-16-2016, 11:28 AM
More detail on the error please.
blackcat4866
12-16-2016, 12:23 PM
My psychic powers seem to be slipping.
What model? What error? Is there some other way that I could know this? =^..^=
tivzualuke
12-16-2016, 01:43 PM
Still requesting to install fusing unit after I changed about 3 different units
tivzualuke
12-16-2016, 01:45 PM
Somebody said I have to reset it there is a particular one that is already registered to the board they need to clear it first
MDR24
12-16-2016, 01:58 PM
If you want help you need to give the necessary information. Saying "you need to do a reset" isnt narrowing anything down.
Whats the model of the machine?
What error are you getting?
Help us, help you.;)
tivzualuke
12-16-2016, 02:04 PM
Bizhub c253
tivzualuke
12-16-2016, 02:05 PM
http://uploads.tapatalk-cdn.com/20161216/687a05e38530def8848aec15b7490e50.jpg
MDR24
12-16-2016, 02:10 PM
Now whats the code your getting?
If the person you got your info from is correct and all your machine needs is a reset, there are 3 different ranks of machine reset Rank A,B and C. The rank depends on what reset you should do. To be honest though i don't see it being a simple case of doing a simple reset.
tivzualuke
12-16-2016, 02:30 PM
http://uploads.tapatalk-cdn.com/20161216/7dbc662ff9663b6aa84a859acf8a22c8.jpg
tivzualuke
12-16-2016, 02:32 PM
From there is doing nothing again
MDR24
12-16-2016, 02:44 PM
We have only started to do the Konicas from C280 onwards so missed these
Easiest way to check if the fuser is registering as an old unit is by pressing utility and then consumable life. If it is empty then follow the below instructions.
If they are like the C280s models it should just be a case of entering the service mode, select counter, select life, press new release then open the front door and highlight fuser then click the print key whilst the door is open. Once youve done that close the door and exit service mode.
That will reset the Fuser count.
Try using the search option on this forum
lots of info on this topic
but if your too lazy to search
http://www.copytechnet.com/forums/konica-minolta/36121-km-c253-fuser-unit-reset.html
based on your posts so far i recommend you get a qualified tech to do this for you
even google search comes up with answer
Konica Minolta Service Manual: How to reset the fusing unit - Bizhub C203 / C253 / C353 (http://kmcopierservice.blogspot.co.uk/2011/03/how-to-reset-fusing-unit-bizhub-c203.html)
tivzualuke
12-16-2016, 03:49 PM
Thanks all. I appreciate your efforts and time.
copier tech
12-16-2016, 04:26 PM
Once you get that message you cant fit used units you need to fit a new fuser unit as they have a quick blow fuse.
You can however cut off the fuse & replace it with a glass 80mA rated or lower, simply solder it in.
Brett GS
12-16-2016, 06:47 PM
Before you do anything else,check your icp's on the printer control board.
In the past i have had a c253 that didnt want to reset the transfer belt and found a blown icp.
allan
12-16-2016, 06:51 PM
Whawhawhahwa
blackcat4866
12-17-2016, 02:03 AM
Darn! I missed out on a whole lot of confusion. I am so disappointed. =^..^=
karim-tech
12-17-2016, 09:51 PM
hi
change the PRCB board i had the same prob with the transfert belt in diff machine ;
good luck
copier tech
12-18-2016, 10:33 AM
hi
good luck
If the fuser units you replaced were brand new (never been put in another machine) then yes you have a failed PRCB board.
If however the units you replaced were used, then simply replace the fuse in the fuser as I mentioned above.
