View Full Version : Miscellaneous BH C280 registration and edge erase questions
COPYDOCAZ
01-19-2017, 04:26 AM
I have a bizhub c280 that has a 6mm void on the trail edge and about 3mm on the top and bottom. I have tried making the adjustments in the administrator, expert, start position adjust. I got the lead edge adjusted but still have the deletion on the trail edge and on the sides. Can someone tell me the simulation to adjust this? PLEASE:cool:
Synthohol
01-19-2017, 12:07 PM
there should be a 3-4mm void around the whole image, this is normal and prevents sticking to the fuser roller.
print a halftone test pattern in svc mode to see the voids better. that will show the max area it can print to.
full bleed is out of the question.
allan
01-19-2017, 03:19 PM
Start with centering the paper trays.
Then do print area adjustment in service mode.
last do the scan area adjustment.
COPYDOCAZ
01-20-2017, 01:14 AM
sorry I'm not sure where that adjustment is in the service mode I know how to get into the tec rep mode but not sure which sub menu has that adjustment.
Thanks for the help guys:rolleyes:
