View Full Version : Error Code 1St paper tray currently not use .
paery80
02-24-2017, 12:13 PM
Hiw can I fix this problem
I check all parts paper feed area
anyone can help me to fix this problem
Sent from my SM-J200GU using Tapatalk
copier addict
02-24-2017, 01:01 PM
I really helps to know the make and model of the machine you are asking about.
paery80
02-24-2017, 01:27 PM
Konica minolta bizhub 363
copier addict
02-24-2017, 01:34 PM
There is likely paper stuck behind the tray.
paery80
02-24-2017, 01:41 PM
Dont have any stuck paper. I checked all sensor and first paper tray motor also all ok
main problem 1St paper tray not show on pannel
2 To 4 Paper tray show on pannel and its working better
copier addict
02-24-2017, 01:50 PM
Then go into service mode and un-isolate the paper tray.
majx75
02-24-2017, 02:11 PM
Also you can remove the paper from the tray and do an "error reset". As long as there is no paper stuck behind the tray, you should be good to go...
nikolai2454
02-26-2017, 03:56 PM
Did you fix the problem for that?
I can help you .
paery80
02-27-2017, 12:11 AM
Tnx everybody already I fixed the problem
myster
02-27-2017, 09:55 AM
How did you solve the problem?
Thank you
nikolai2454
02-27-2017, 04:55 PM
Follow theese steps:
1.Utility
2.Check details
3.SERVICE MODE: stop >0>0>stop>0>1
4.System
5.Trouble Isolation
6.Tray1 Set to unset
Thats all!
paery80
02-27-2017, 05:05 PM
Thanks nikolai
