View Full Version : screw mark problem C1060
Shinigami
03-02-2017, 10:19 PM
I have the problem of slant white lines in screw pitch occurs at the whole page.
i changed the developer two time !
Phil B.
03-03-2017, 02:43 PM
can you provide examples?
Shinigami
03-03-2017, 02:54 PM
Like this one in magenta
mx6turbo89
03-03-2017, 03:39 PM
Is it happening on all colors or just Magenta? How many total prints on the magenta developing unit?
Shinigami
03-03-2017, 03:45 PM
I have the same problem with 2 differents machine in 2 differents color ! The developers is one 45 %
mx6turbo89
03-03-2017, 04:28 PM
That problem will happen if the machine sits for long periods or if the customer does nothing but continuous low-coverage printing. Humidity also plays a factor, as well as the levelness of the machine.
You can fix the problem by increasing the developer conveyance speed. Change DIP SW 46-4 to a '1', then do Gamma Automatic Adjustment. Also change DIP SW 44-5 and 44-6 to a '1'.
Since your current developer is depleted, it'll take a few hundred copies for it to get toned back up after performing the above settings.
Shinigami
03-03-2017, 05:32 PM
Thank you so much for your help !
