View Full Version : Brother 2820 error
kmguy31
08-13-2008, 06:41 AM
screen reads "unable to print, refer to users guide" checked the guide, says power off/on. tried. let sit for a few hours. tried again. same thing. machine has only been in the field for a 3 weeks. any ideas?
raym
08-13-2008, 02:51 PM
you can try doing a reset by entering "menu/set" & "*2864" all within 2 secs. you should see "maintenance" on screen. if not, try entering code again. once in maint. mode, enter "91". should say "parameter init." enter "99" to exit. if there is a true problem, you should see some sort of code pop up.
hth,
ray
kmguy31
08-13-2008, 09:05 PM
thanks, tried that. no help. kicks me back out to the same screen reading "unable to print"
jtymabel
09-16-2008, 10:30 PM
menu, * , 2,8,6,4 and then 82.. should give you error code log or list. then let us know...
jtymabel
09-16-2008, 10:32 PM
also check the back door to make sure the paper flag is not broken.
E Winter
09-20-2008, 08:02 PM
or try service function 01 for full factory reset
