View Full Version : Error Code Konica Minolta 421
Scott
04-28-2017, 03:32 PM
I have this machine with a c-2801 code and it's making a grinding noise toward the rear of the machine...any ideas??? Thanks in advance
Scott
prabinkumar
04-30-2017, 05:53 AM
Scott
2801-tcr level abnormality.toner flow from the hopper to developing unit is not correct
toner hopper may jammed . the sound is from hopper gear slipping while running. open the toner hopper section and check.
Scott
05-01-2017, 09:55 PM
thank you!!
Woxner
05-01-2017, 11:29 PM
probably need to replace the sub hopper assy
blackcat4866
05-02-2017, 12:20 AM
It was fairly common on that series for endusers to mis-align the toner tubes and get them seriously wedged in there. Does it rotate if you key the door? =^..^=
