View Full Version : Check one of the snapshot
tivzualuke
05-06-2017, 01:37 PM
https://uploads.tapatalk-cdn.com/20170506/c4c4bd0b3d0533233fa518dc21055965.jpg
Sent from my Infinix HOT 4 using Tapatalk
Synthohol
05-06-2017, 02:10 PM
looks like you need black toner?
blackcat4866
05-06-2017, 02:23 PM
I think that I'd start by washing off the operation panel. It looks like you'd stick to it, if you were to touch it.
Maybe it would be pertinent to know what model bizhub this is. =^..^=
tivzualuke
05-06-2017, 02:33 PM
No full the cartilage
tivzualuke
05-06-2017, 02:35 PM
I mean toner the cartilage
tivzualuke
05-06-2017, 02:36 PM
Toner full the cartilage
Synthohol
05-06-2017, 08:46 PM
well the chip on the bottle is not being read, either bad chip or check the 3 gold terminals on the machine that make the contact with the chip.
Brett GS
05-14-2017, 06:08 PM
Check toner conracts and make sure they not bent.
marvin_PL
05-18-2017, 09:00 PM
There's no chip.it's bizhub c220 series
habik
05-18-2017, 09:23 PM
Try to manually add toner in service mode.
or
Take the exit tray cover off and have a look if the bottle is spinning. remove the bottle and have a look if there is any toner inside the hopper. If it is then switch the machine off and pull the drum and dev unit out and check if the dev unit is getting toner inside. If it does then check if the door switch is operating OK if there is no tonner in hopper or dev then remove the tonner hopper and clean everything you see. Sensors, vacuume the hoppers and then check for proper operation of actuators and agitators and shutters manually.
Check in history if there is any C-Codes.
