View Full Version : Bizhub c552 misaligned image
konica7022
05-12-2017, 07:44 AM
Hi guys
C552 suddenly started give replace K drum / Set developer error
so swapped few K IU units
it works but now give prints like this
36588
i swapped Transfer belt, Cleaned the laser heads but no difference, Black print comes out fine but in color its out of focus miss aligned
Synthohol
05-12-2017, 12:07 PM
post a pic of the demo page from the engine.
konica7022
05-12-2017, 05:04 PM
36610
Synthohol
05-12-2017, 07:29 PM
Looks like a slight skew is making it a registration issue.
Reset the skew in service mode and do a manual registration adjustment.
Clean the 2 sensors under the plate under the belt then adjust.
Remember all colors use black as the reference point so there is none for black.
konica7022
05-13-2017, 10:35 AM
Thanks dude ... Resetting the Skew Sensors did the trick
i did not set any of the registers manually
Can i set the TSR sensor for the black manually to avoid getting error c2558
PS; do you watch THE E X P A N S E series?
Synthohol
05-13-2017, 06:48 PM
Thanks dude ... Resetting the Skew Sensors did the trick Awesome!
i did not set any of the registers manually thats ok
Can i set the TSR sensor for the black manually to avoid getting error c2558 why? if it cant replenish by itself there is another issue at play
PS; do you watch THE E X P A N S E series? no, didnt get around to it. :)
konica7022
05-13-2017, 07:22 PM
I think it happens when i swap the Black IU from 452 to a 552 machine so i keep getting this error c2558, so i open and close the front door it starts working again some times i have to add black toner manually after a week or soo
