View Full Version : Miscellaneous Konica Minolta Bhc 7000 stays warm and does not fail
venetech
05-24-2017, 05:56 PM
I have a Konica Minolta Bhc7000, the same gets ready, but when making several impressions gives the message "wait a little, the machine is heating up". And so it stays all the time and it does not give fault code, I'm a Venezuelan technician, thank you very much s help, Regards
tonymac
05-24-2017, 07:10 PM
most likey its the upper fuser lamp causing that problem. you might want to try to clean the thermistors also.
Jimmy:)
05-24-2017, 07:23 PM
You can probably do a couple of things.
Try to remove all finishers and see if you get the same issue.
Also try changing software sw settings in the service mode
19-1 to 1
19-2 to 1
19-3 to 0
Hope this helps, I had the same issues and this solved it on our end but there are many different "Please wait signs".
Good luck
venetech
05-24-2017, 08:17 PM
Replace, fuser lamps, thermistors, fuser band, and still the fault
Synthohol
05-24-2017, 11:37 PM
warm up is not just heat, its also self calibrating. clean your ITB/Reg sensors. make sure the belt isnt wrinkled or wavey.
ysshin79
05-25-2017, 12:43 AM
I had two cases.
The warming up was continued on the C6501.
It is under the fusing unit.
65AA 5365 1 - FIXING LIMITER
In the C7000, the PHOTO SENSOR was replaced at the bottom left of the fusing unit gear assembly.
08AA 8551 2 PHOTO SENSOR
A50U M555 00 PHOTO SENSOR
You can order any of the sensors above and replace them.
venetech
07-05-2017, 05:20 PM
Ready, replace ps16 and limiter fixing, resolved the fault, many thanks, Regards:)
