View Full Version : BH-C-353, TB ruptured
Hansoon
05-29-2017, 09:53 AM
BH-C-353, TB ruptured and CYM drums destroyed. Any known reason why this can happen with less than 200K? There is a TB blade flip but I'm not sure if that happened before or after the calamity. See attached pics.
3671836719
What can cause a TB to become that much damaged?
Hans
lazymangr
05-29-2017, 10:41 AM
i have seen damaged transfer belts but nothing like this. the leftover toner means that the cleaning blade didnt work. maybe paper passed through it? i have seen more than 1 time, customer uses normal trays for labels and they got stuck on it. but i have no idea what caused the rupture.
copier addict
05-29-2017, 01:37 PM
C353 transfer belts are only rated for 150k yield. That could have contributed to this failure.
blackcat4866
05-29-2017, 03:33 PM
I've seen a few catastrophic failures on C554e but I attributed it to the huge volume of printing going through this particular machine. The blade was also flipped on mine, but I could not determine if it was a cause or an effect:
3672236723
allan
05-29-2017, 05:27 PM
I don't know, golf balls and razor blades?
Frustration?
How long did it run like that?
allan
05-29-2017, 05:34 PM
If that bead on the inside of the belt goes...
Caught one just in time.
Had one a couple of days ago. But still why?
Hansoon
05-29-2017, 05:55 PM
Anyone having for me the bulletin pertaining service code C-2152 and the modification of the slider on the TB please?
Hans
allan
05-29-2017, 06:17 PM
Did it come loose?
Hansoon
05-29-2017, 06:25 PM
Allan, sorry pal, I don't know what "bead" you meant, thought you where joking or sipping too much of that fine South African wine. LOL :D
What bead can come loose?
Hans
Nommo
05-29-2017, 06:48 PM
Hans
Take a look at your PMs :)
blackcat4866
05-29-2017, 06:52 PM
I think allan means that 7mm wide plastic strip on the edge of the belt, and it's seamed at some point, the vulnerable spot. =^..^=
habik
05-30-2017, 07:03 PM
As to that bead, yes that is the strip which can come loose when the belt gets its wear in the nicer scenario it just wraps around a drum. In the bad scenario it goes anywhere.
How does the K - 1st transfer roller *(TR) on that belt looks like? Any damage on the bushings for any of the first TR's
What is the coverage of colour? Is the belt set to BW or Colour Priority?
