View Full Version : Miscellaneous 454 firmware
devontug
09-08-2017, 08:53 PM
Who can help me with this issue I have upgrade firmware for the printer listed above but I can't get the machine to upgrade at doesn't boot from thumb drive can't someone tell me what should be in the rood it the thumbdrive??
copyman
09-08-2017, 09:07 PM
are you using USB behind small metal cover in rear? It won't work from USB on front right side near control panel, only movie F/W can be loaded there.
Only file on thumb drive should be the .tar file
devontug
09-08-2017, 09:12 PM
Yeah I'm using the port behind the metal panel that slides up
Woxner
09-08-2017, 09:29 PM
what size is drive? may need to use a different thumb drive. not all of them work
copyman
09-08-2017, 09:30 PM
Correction, the .tar file is for movie data.
For regular fw you open yellow folder and copy and paste ALL the files onto thumb drive. plug into rear usb port and turn machine on. I've had to wait 5+ mins for it to show on display.
devontug
09-08-2017, 09:31 PM
Sandisk 2gig
devontug
09-08-2017, 09:54 PM
When I open yellow folder just copy those two?
https://uploads.tapatalk-cdn.com/20170908/e20d4c805579f05ce036534075de33f7.jpg
Synthohol
09-08-2017, 11:10 PM
open the A2XK0Y0 folder and select all and thats what you copy to the root of the flash drive.
devontug
09-08-2017, 11:33 PM
https://uploads.tapatalk-cdn.com/20170908/3aeb5a33ccccd0015d17600340e6515f.jpgthis is all I see when I extract file
copyman
09-09-2017, 01:13 AM
either "select all" those files and move to thumb drive or copy and paste all those files to thumb drive. confirmed they all are the correct files
devontug
09-09-2017, 01:58 PM
Hey guys I upgraded the firmware now I don't have access to my CE password or admin none of the defaults wrk is there a way to reset this ?
Synthohol
09-09-2017, 02:02 PM
i never saw firmware change that, what else happened?
devontug
09-09-2017, 02:10 PM
All I did was upgrade https://uploads.tapatalk-cdn.com/20170909/c53d8b732351c2e6a504b7b54e50f127.jpg try to access my admin and CE and can't
Synthohol
09-09-2017, 03:09 PM
boot holding reset and see if you can get to service mode after hitting trouble reset and format the HDD.
you can also unplug the HDD and wipe it on a PC and reinstall, format and install movie data.
try going into admin mode first because the option to format will be the first thing to pop up
devontug
09-09-2017, 03:11 PM
Trouble rest still asking for the pass word
devontug
09-09-2017, 03:13 PM
Admin password is also not accessible default password is not working ... I thought the firmware upgrade would set all password to default
copyman
09-09-2017, 04:19 PM
what default password are you using? can be "12345678", "00000000", "9272927292729272". Also try inputting each password 2 times without a space.
devontug
09-09-2017, 04:25 PM
Tried 12345678 twice and 9272xxxxxx twice will check the "00000000" and let you know
blackcat4866
09-09-2017, 04:29 PM
No big deal. Just set an encryption passphrase. It's not unusual for that to clear/reset when you've formatted the HDD. It's in the Admin Settings menu, let's see if I can find specific keystrokes:
In Admin Settings > Security Settings > HDD Lock Password > enter 20 digit passphrase > Ok > re-enter passphrase > power MFP Off/On.
It doesn't really matter what your specific passphrase is, as long as you can type it exactly the same on two separate lines. Essentially Konicas encrypt the data on the HDD with a 20 digit password to make it unrecoverable. =^..^=
devontug
09-09-2017, 04:33 PM
I can't get into admin
blackcat4866
09-09-2017, 04:54 PM
What admin password are you using? Has it been changed? =^..^=
devontug
09-09-2017, 04:57 PM
"1234567812345678" plus all the other default passwords I know ... is there a way to reset to default? Admin or CE password
blackcat4866
09-09-2017, 05:08 PM
Power Off/On. Three consecutive wrong tries locks the machine. =^..^=
devontug
09-09-2017, 05:13 PM
Yeah I Kno ... but when it comes back up still don't know what to try... can it be rest to default?
Synthohol
09-09-2017, 05:22 PM
firmware should not have done this.
did you try and swap boards or something?
Woxner
09-09-2017, 05:31 PM
you may need to use the reset tool now. there is a bulletin where to enter part of the serial and code to try and reset.
Use the numbers in the serial twice followed by 8 zeroes. An example for the bizhub C360 serial number is A0ED012020866. (Do not use the item number A0ED012portion.)
The unlock password using the above example is 02086602086600000000.
devontug
09-09-2017, 05:46 PM
Not sure bought it used
blackcat4866
09-09-2017, 06:01 PM
Sounds to me like somebody else gave up on it before passing it along to you. =^..^=
copyman
09-09-2017, 08:51 PM
did you try "9272" 4 times ?
devontug
09-10-2017, 07:57 AM
Yes I did
copier tech
09-10-2017, 09:19 AM
Did you have this issue before you updated the FW? Or were you updating the FW to fix this or another issue?
devontug
09-10-2017, 01:46 PM
To fix this thought it would master reset the defaults
habik
09-10-2017, 08:11 PM
You need Konica Rep to help you on this one or try what Woxner suggested.
nassor
09-12-2017, 10:34 AM
Try to use different
USB flash drive.
devontug
09-12-2017, 04:17 PM
USB flash drive.
Yeah I did thanks and i got it upgraded ....
Have some CE password issues
devontug
09-12-2017, 04:19 PM
Is there anyway to get into service mode through administrator mode? Or change CE password just a question I'm at a lost now ready for trying anything
blackcat4866
09-12-2017, 07:44 PM
You 'll need to call the hotline to get the CE password reset. They give you a code sequence. =^..^=
