axyun
11-07-2017, 04:48 PM
Customer called yesterday with Bizhub 223 that has message under READY TO COPY that says " tray 1 cannot be used currently" and on a white screen it says
"Load the paper in the proper position in the bypass tray or select a paper tray " underneath that it shows "paper" on the left then what paper to load, which in this case is 11x81/2 short way (not reduction way), and then type of paper, which is "plain" in this case. Customer sent me text photos. I have not been there but will be there today. As it is a good distance from me I wanted to be prepared. I thought I would
look behind tray1 to make sure no paper is behind it. Check the paper setting and how trays are loaded and check tray settings in system settings and see if lift motor is activating.
Please add any info that you feel would be helpful . Frank/ Action Photocopy
