View Full Version : Bizhub c284e Ce password reset?
mrfuser
12-06-2017, 09:36 PM
Client has a c284e that someone changed the password on. I can get to service mode but canít change it. Any ideas how to set it back to default?
rrrohan
12-07-2017, 12:14 AM
If you glitched your way past the password screen just turne off CE authentication. Otherwise you have to call KM for reset code
copier addict
12-07-2017, 12:59 AM
[QUOTE=mrfuser;586107]Client has a c284e that someone changed the password on. I can get to service mode but canít change it. Any ideas how to set it back to default?[/QUOTE
If you somehow got into service mode. doing a data clear will reset the password to default I think.
Woxner
12-07-2017, 03:54 AM
if you got into service mode then hit stop 0 c then touch ce paswword you can just turn this off
mrfuser
01-16-2020, 05:37 PM
I updated firmware and reset it then to default
Synaux
01-17-2020, 03:26 AM
FrImware resets CE pass? Is this a "new" feature? Pretty sure that didnt work on older models.
mrfuser
01-17-2020, 03:49 AM
It does and when you go back into service mode you can set it as you like.
Synaux
01-17-2020, 07:37 AM
WHAT?
What in the world are you talking about?? You cannot get into CE pass without getting into SM FIRST--which requires the CE pass!
The basis of your inquiry is "Bizhub c284e Ce password reset?".... Someone correct me if I am wrong, but this person is fused (get it?).
Mind Blown....
I need Phil to come here am set me straight! (perhaps I am fundamentally mistaken?)
mincopier
01-17-2020, 10:46 AM
Firmware resetting the password as a tool is not likely. It might be possible that it reset a corrupt switch that allowed the password to work though. Other than that to reset the CE Password with the CE Authentication on you would normally need a NVRAM reset tool. Sometimes going through the "Trouble Reset" screen can allow you into service mode without a password. You can then use the "Stop, 0, Clear" to get into Security mode to reset the CE Password, Turn it off, or reset the Administrator password.
mrfuser
01-17-2020, 04:02 PM
Calm down yíall, talking admin NOT ce
tsbservice
01-17-2020, 04:24 PM
I may be wrong but maybe some of the guys vented because your thread name?
mrfuser
01-17-2020, 04:32 PM
https://www.copytechnet.com/forums/blob:https://www.copytechnet.com/3e4c4d6f-f7ee-47f3-8e52-094b90f5ad45
QUOTE=tsbservice;1198199]I may be wrong but maybe some of the guys vented because your thread name?[/QUOTE]
Synaux
01-18-2020, 03:06 AM
I might have gotten carried away. :rolleyes:
However, I am too dumb sometimes to keep all this stuff in my head:
If people here--people I respect--start saying that on the newish models that a FW will reset the CE pass enough times, I am liable to start believing it (or at minimum start questioning what I thought I already knew--which can be arguably even worse). Moreover, the guys/gals new to the industry or techs that work on predominately on other brands do not stand a chance reading such things. It kind of amazed me that no one jumped on this from the onset...
