View Full Version : bizhub c220 need first setup installation
avio2
12-07-2017, 09:07 AM
good morning
I would need the pdf before installation, having had to reinitialize the machine and format hd, someone has the pdf?
tank's in advance
habik
12-07-2017, 09:14 AM
good morning
tank's in advanceFrom top of my head, been a while.
Enter service
Time : Stop 1144C
Time / date in Admin mode
Serial no
Non Image Area Erase
Gradation for each mode 3x
List Output
HTH
Sent from my Mi A1 using Tapatalk
Zesti
12-07-2017, 09:22 AM
Enter service
Time : Stop 1144C
Serial no
List Output
HTH
Habik u r quick....
D Colour
12-07-2017, 10:51 AM
38362
38361
avio2
12-07-2017, 01:16 PM
38362
38361
tank you
avio2
12-07-2017, 01:19 PM
I hope to solve the problem faded and banded copies by reinstalling it
I have both this and a 224 that consumes the dv:mad:
copier tech
12-07-2017, 01:37 PM
good morning
tank's in advance
You wont need to do the setup as if a new machine by simply doing an all clear.
You will need the animation file as you’ll get a message staying its missing.
avio2
12-07-2017, 06:14 PM
[QUOTE = copier tech; 586200] Non è necessario eseguire l'installazione come se si trattasse di una nuova macchina semplicemente facendo una cosa completamente chiara.
Avrai bisogno del file di animazione man mano che il messaggio mancherà. [/ QUOTE]
this machine have problem whit faded copy and blank band whit only 100k bn and 40k color
i have read a tech:(nical bullettin with similar problem for not correct setup installation:(
habik
12-07-2017, 07:24 PM
i have read a tech:(nical bullettin with similar problem for not correct setup installation:(Laser cleaning wand when pulled incorrectly causes the wand to create a bow (by leaning wand to the left whilst pulled out or inward)
Dev refresh by doing sky shots or full halftone may improve or manual toner add.
Have you examined the Devs!?
