View Full Version : ICP14 replacement component (Konica C6501)
methogod
01-31-2018, 06:29 PM
Blew a conveyance board by plugging the fuser connector in wrong. I know ICP14 is blown and I know why...
It has a 2.3A and 939 on it. Is this correct replacement?
I know its a 24V line protection, just not sure how high the cut out should be, working voltage and breakdown voltage.
https://www.mouser.com/productdetail/littelfuse/tpsmf4l20a?qs=sGAEpiMZZMvxHShE6Whpu6Nd87lSCAmD%2FZ i8LA2%2FCGU%3D
38747
Albonline
02-01-2018, 07:59 PM
38747
i use 2.5 amp inline fuse for these.
methogod
02-01-2018, 08:04 PM
how many volts? its on a 24v line...
links the correct product?
I found the right items just are coming from china...
Albonline
02-01-2018, 08:20 PM
2.5 amp 125v micro fuse, tried 2 amp but blew instantly at copier startup.
Albonline
02-01-2018, 08:21 PM
i buy them localy at an electronics retailer.
pudgi300
02-02-2018, 03:13 PM
If you have some old Konica boards you may find some ICP's on them. I posted this fix a while back Search ICP14
C-3102 on C6501 ICP 14 open
Was replacing fuser belt and when reinstalling fuser must have shorted CDB board. The long purple wire connector was broken on one end so must have installed connector 1 pin off. Would get C-3102 on startup. Pulled CDB and found ICP 14 open. Replaced fuse and back up and running. Another tip i found is that when we scrap old machines we remove the ICP's off of them. Posted this in the hope it helps someone in the future.
methogod
02-02-2018, 05:05 PM
Thanks, that is exactly what we did....
