Synthohol
02-13-2018, 10:00 PM
the dumbest thing i ever saw on a forum was typing the word Print and it shows in a printable view so you cant answer the thread or open attachments.
please fix the forum admin? WTF?
anyway, heres the thread reposted so others can reply.
BizHub 751 Streak/Line on Print (http://www.copytechnet.com/forums/konica-minolta/127082-bizhub-751-streak-line-print.html) Printable View
02-13-2018
Ascule
2 Attachment(s)
New to the forum.
I searched for my issue before posting, didn't find anything that helped my specific issue.
I have a consistent streak at the bottom of every print regardless of paper type/size.
I scanned a printout. The streak has been lightened quite a bit, but you can still see the location of the streak. Its actually visible the across the entire image.
(See attached pdf)
I've found a few manuals for the 751, but nothing that gets into troubleshooting very deeply at all. Best I've found was a user manual that said to basically "clean the glass".
Found a service manual on here. While very indepth with exploded parts listing, there isn't much at all about troubleshooting.
I found a roller loose on what appears to be an imaging unit (again I don't know because I can't find a manual to confirm the name). The roller was detached on one side and jammed. Theres burned toner on the roller that can be seen on the pic. I tried to scrape it off but its very well burned in.
(See attached image for re-attached roller)
Any help is appreciated.
02-13-2018
Ascule
2 Attachment(s)
New to the forum.
(See attached pdf)
