View Full Version : C350 with booklet finisher
rasman67
09-15-2008, 03:51 PM
I have a C350 that I installed but the folding doesn't show up as an option. If I place the finisher on a C450 it shows the folding option. What do I have to do to get this feature to work on the C350.
Thanks in Advance
WaveyDavey
09-15-2008, 03:54 PM
is it just the folding feature or does the finisher not show at all?
rasman67
09-15-2008, 03:57 PM
Yes I have The hole punch and stapling features
WaveyDavey
09-15-2008, 04:13 PM
do you have a duplex unit fitted? booklet will not appear if you don't
rasman67
09-15-2008, 04:25 PM
yes it has the duplexer
WaveyDavey
09-15-2008, 04:39 PM
which model finisher is it? FS603?
Specilist KVN
Thanks in Advance
If the finisher shows up in the driver as an installed option then it is in your settings.
Have you tried different stock sizes and weights?
If it is not showing in the driver, configure the 2-way communication or add the finisher as an option.
Also, you need to exit the program sometimes when reconfiguring the driver.
WaveyDavey
09-15-2008, 04:42 PM
yes is this folding option not available on the desktop or not available on the control panel?
Albonline
09-15-2008, 04:45 PM
what modle finisher? c350 uses fs601 c450 uses fs603.
WaveyDavey
09-15-2008, 04:49 PM
thats where I was going
rasman67
09-16-2008, 03:05 PM
I'm using an fs-601 and it is not showing up on the op panel, but the fs-601 will show the fold/staple mode on the c450 op panel just fine.
