View Full Version : Scanning to windows 10
Johnny
03-06-2018, 08:18 PM
We seem to be having a lot of problems getting the Konica Minolta machines to scan to smb with windows 10. Never have any problems when customer is using windows 7. I believe it's a security thing or permissions thing but so far can't find it. Would appreciate any suggestions. THANKS!
Johnny
Albonline
03-06-2018, 08:20 PM
there are many threads on this site about this. search it!
guitar9199
03-06-2018, 08:56 PM
First thing, make sure you have a valid User ID/PW for the scanner to use. Anonymous browsing is no longer a thing.
Second, Share the living daylights out of the folder. Make sure that USER ID/PW has full permissions.
Third, go into your TCP/IP v4 Properties/Advanced, select the WINS tab, and change the protocol to NetBIOS over TCP/IP. It's likely defaulted to NetBIOS over DHCP, and scan to file doesn't like that.
mincopier
03-06-2018, 09:06 PM
Update the machine firmware to the latest and greatest firmware.
AjitN
03-07-2018, 06:34 AM
Try putting OFF windows firewall for trial. If antivirus have its own firewall also check same.
I think Win 10 Uses SMB 2 and do not support SMB1. I am not sure about this inf. which I came across somewhere but you can try.
Hope this helps
MOTANU
03-13-2018, 04:08 PM
try instead to maake the conection ftp using ftp utility from konica minolta Download KONICA MINOLTA FTP Utility by Konica Minolta Business Solutions (HK) Ltd (http://konica-minolta-ftp-utility.software.informer.com/download/)
and on the web interface on the file path insert just "."
JLSam
03-13-2018, 04:20 PM
Hope this helps
https://support.microsoft.com/en-us/help/4034314/smbv1-is-not-installed-windows-10-and-windows-server-version-1709
This is true.
Synthohol
03-13-2018, 07:05 PM
What version win10?
Home and basic edition are complete trash in the workplace
A cheat I learned is if you open file manager (windows explorer) and type in //ip address it should show the current shares on that computer.
You can make a sub folder in one and try that. Just add the specific user to the share permissions of that sub folder and the main share.
mincopier
03-13-2018, 07:36 PM
Make sure network type is set to private
Right click shared folder, sharing tab, permissions, advanced permissions and make sure user has sufficient rights
Same with the security tab
At the copier, Administrator, network, SMB Client enable NYLM V1/NTLM V2
bsm2
03-13-2018, 08:56 PM
use filezilla ftp server and applied firewall wall setting for it
REGSIS
03-13-2018, 09:05 PM
This is true.
And now even regular updates can uninstall SMB 1,
najoor
03-17-2018, 11:05 AM
Johnny
remove update security windows 10
Problems with Internet Connection Sharing after 2017-11 Windows 10 - Microsoft Community (https://answers.microsoft.com/en-us/windows/forum/windows_10-networking/problems-with-internet-connection-sharing-after/3c83baac-1be9-4869-80e4-c0691bc2a131)
wjurls
03-20-2018, 10:56 PM
Going through this issue right now at the school district. Older builds of Windows 10 accept SMB scans just fine from Bizhub "4" and "e" series. The latest build of Windows 10 has some security updates that blocks SMB 1.0 and 2.0. These updates were needed due to some ransomware worms that exploited it. Bizhub "8" series machines already support SMB 3.0 and can scan to all builds of Win 10 just fine. No firmware updates to add SMB 3.0 to older Bizhubs are available yet. Hopefully KM will address this soon.
I will update here as soon as a solution or viable workaround is found.
Lee
The Copy Guys
guitar9199
03-21-2018, 02:58 PM
Lee
The Copy Guys
One of the things I've run into is "NetBIOS over DHCP" in the IPv4 adapter. SMB doesn't seem to like that too much. Go into the properties of the IPv4 adapter, click the Advanced button and WINS tab, and change it to "NetBIOS over TCP/IP", and see if that makes a difference.
Elmo
03-21-2018, 05:21 PM
You can turn SMB 1 back on
go to add /remove programs---type windows features into the search box
it will load features list
scroll down to SMBv1/CIFS
you have 3 options
remove tick from auto removal option
This will allow SMBv1 to work
it not an ideal solution but can help if your waiting for a firmware update for the machine
Elmo
03-21-2018, 05:23 PM
At the copier, Administrator, network, SMB Client enable NTLM V1/NTLM V2
if you can enable NTLM v2 on your device this will work without having to turn SMBv1 back on at your pc
REGSIS
03-22-2018, 07:01 AM
Didn't work for me. Only turning back SMB 1 on win 10 made it work.
Elmo
03-22-2018, 09:27 AM
you often have to switch the smb client port to 445 aswell
Synaux
02-07-2021, 03:22 AM
you have 3 options
I know this is an old post, but just ran into this. Elmo's reply was the only thing that worked for me on c654s (and naturally the last thing I tried). Seems that only SMB 1 Server needs to be installed
Was there ever a FW to fix this? Perhaps the E version up?
CP-1015
02-07-2021, 08:14 AM
Johnny
It would be interest from what machine you want to scan. The 4e-Series scan with older firmware only SMB1-Protocol with newer firmware although SMB2-Protocol. Than open PowerShell as administrator and check the networkcategory:48183
Get-NetConnectionProfile
Afterwards:
Get-SMBServerConfiguration
48184
copier tech
02-07-2021, 10:28 AM
Yes, there was a special firmware release to enable SMB 2/3 support on the C654 series.
The 'version up' firmware was different, that was to address scanning via SMTP issues & other fixes.
48185
mincopier
02-07-2021, 02:17 PM
I used to use the G00-72 (2-10-2014) version up firmware then do the special firmware GDB-M1 (allows SMBv2/v3) on our machines. Since then there is now a GBE-A9 (9-17-2020) version up firmware and newer SMBV2/V3 firmware. I have yet to look at it to see if it has SMBv2/V3 in it or not. It should since it is newer than the firmware I was using. Since it worked for us I had not checked into newer firmware. We have been replacing our 4 and 4e series fleet with newer machines so this has not been coming up for us as much as it used to. I have also noticed that Microsoft is turning off services that they have deemed either not needed or a security risk. Some of these SMB sharing depends on and even after enabling sharing does not allow the copier to work even if 2 computers are able to share files. The following can be pasted into a new txt document and and saved as a batch, .bat, and ran. This way you do not need to go through services to enable each one. I do have a more complete batch file that does nearly everything I need at the computer such as, creating the "Scans" user with the PW "Scanner1" which can be changes. Creates the scans folder, shares it as Scans and creates the shortcut. Manipulates the Windows firewall and the below services. I have a 95% success rate on most Windows computers with it. Those that do not work I usually have to go into the Sharing tab of the Folder properties, Permissions and add my user there with full permissions. Sometimes the batch file does this and other times it does not. The other reason would be third party firewalls and computer be locked down by customers IT.
rem Workstationsc config LanmanWorkstation start= auto
net start "LanmanWorkstation"
rem Server
sc config LanmanServer start= auto
net start "LanmanServer"
rem Routing and Remote Access
sc config RemoteAccess start= auto
net start "RemoteAccess"
rem Remote Procedure Call
sc config RpcSs start= auto
net start "RpcSs"
rem Function Discovery Provider Host
sc config fdPHost start= auto
net start "fdPHost"
rem Function Discovery Resource Publication
sc config FDResPub start= auto
net start "FDResPub"
rem SSDP Discovery
sc config SSDPSRV start= auto
net start "SSDPSRV"
rem TCP/IP Netbios Helper
sc config lmhosts start= auto
net start "lmhosts"
rem UPnP Device Host
sc config upnphost start= auto
net start "upnphost"
rem DNS Client
sc config Dnscache start= auto
net start "Dnscache"
rem Device Association Service
sc config DeviceAssociationService start= auto
net start "DeviceAssociationService"
rem Remote Registry
sc config RemoteRegistry start=auto
net start "RemoteRegistry"
aw10569
11-15-2023, 07:57 PM
Thanks to all seniors, as I faced this problem today, in Bizhub C280 where scanning was failing to reach into the network folder (Windows 10). I have tried with smb v1 then v2 then ftp utility of KM, then I tried with filezilla server and many more special settings of windows 10. But the problem was not resolved. Finally I decided to load the firmware of C280.
FW file name: "A0ED0Y0-F000-G00-D2".
After updating the complete firmware, restarted the machine and all the functions of smb and ftp worked majically.
So, After the 4 Hours long hactic excersise, I got the success with fw update.
ThankYou for all of you.
