View Full Version : Error Code Error code c2253
bunchieattia
04-21-2018, 07:00 PM
Hi Guys,
I have a c360 Konica Mionlta that pops up c2253 when ever I send print in color
It said the PC DRUM Motor, But I noticed it wasnt the motor but some BOARD, CAN YOU PLS IDENTIFY WHICH BOARD IS THAT ????
Synthohol
04-22-2018, 05:47 AM
Various error codes, such as C2152, C2253, C3201 and C5102 may be indicated as the MFP begins to run through stabilization. All the errors are drive motor related.
Solution
CAUSE: The MFP power supply is failing.
SOLUTION: Replace the power supply (p/n A0ED M400 03).
mdtrinh
09-25-2018, 05:59 AM
Hi Guys,
Are you able to resolve the problem?
I got a C360 with C2253 at power on, and replace power supply, but problem still the same.
mdtrinh
09-28-2018, 11:34 PM
Finally, it turn out to be bad Color PC Motor, just behind controller box.
