View Full Version : Miscellaneous Konica Minolta C224e - Not Printing/Copying
Optimus Prime
05-09-2018, 05:02 PM
Afternoon,
I have a KMC224e that doesn't print or copy.... The machine turns on and comes to ready and you can take a copy as you would normally i.e the document goes thru the feeder ok. The machine flashes at the front and you can see the job in the history but it doesn't come out or make the processing noise.
I've done the following:
Updated Firmware
Formatted the HDD
Ran the diagnostics in 'State Confirmation' - everything checks out OK
Performed the 'Data Initialization'
Any thoughts about this would be appreciated before it gets expensive :eek:
allan
05-09-2018, 05:39 PM
one of the parts is over life. I think...
Try soft switch 51 HEX F0 and 55 HEX 0C.
copier tech
05-09-2018, 06:05 PM
If your parts life are not at life stop check user authentication/account track has not been enabled.
