View Full Version : scan to usb current settings
Bix
07-06-2018, 10:28 AM
Hello, a question perhaps stupid.
In copying and scanning, I can set the default settings (ie the current settings).
But I have difficulty finding a similar option for scanning to usb. The customer would like to black by default and not the color scan.
Do you know how to set this up?
Synthohol
07-06-2018, 12:47 PM
i dont think there is a setting for that. it takes literally 1 second to hit auto color and change to black.
copier addict
07-06-2018, 02:25 PM
Set it to black then go into utility- user settings= scan/fax settings- default scan/fax settings- current settings- okay.
Bix
07-02-2019, 04:22 PM
lol, I suffer from a short memory.
I have the same problem, trying to rediscover my old thread.
However I still haven't been able to find an option that allows me to set the default black and white in the scan to usb.
@copier addict your solution is correct but concerns the normal scan. Unfortunately this does not affect scan to usb.
Bix
07-02-2019, 04:45 PM
I succeeded!
You insert the USB stick. At the top right there is "Check settings". Now a popup comes out. You press "Use current settings".
srvctec
07-02-2019, 10:02 PM
Since it wasn't mentioned anywhere in this thread for some reason and is important.
This only applies to 7/8 series and later. The 4e series does not have this option.
