View Full Version : Trouble shooting - fs532 j-7229
ysshin79
07-13-2018, 12:22 PM
☆ Trouble shooting ☆
※ Symptom - Intermittent finisher JAM (J-7229) occurred
※ Model with FS-532 Finisher
KM bizhub PRO 951 PRESS 1052,1250
※ Cause - Finisher exit sensor JAM occurs when the paper badge can not be detected due to contamination of the light receiving part.
※ How to handle - After cleaning the part appearing like a black non-woven fabric under the exit sensor of the finisher (responsible for the exit sensor sensor), solve the symptoms.
☆ ☆ If you continue to clean the light-receiving part, J-7229 symptoms will not be treated even if you clean it later.
Applying the light-receiving part with black oil magic will make it completely processed.
Or replace the non-woven material parts of the light receiving part.
ysshin79
07-13-2018, 12:29 PM
4011340112
40111
Phil B.
07-13-2018, 03:09 PM
ok do you have a point to make or a question to ask about a problem?
blackcat4866
07-14-2018, 02:13 AM
ysshin79 has found a solution and is sharing. Thank you sir.
I can't read his handwriting on the samples though. =^..^=
ysshin79
07-27-2018, 01:03 PM
Thank You Sir.
I am Korea Republican.
Sample handwriting is Hangul.
The handwriting is in Korean language, and painting the sensor sensor with a black oil pen means that the symptoms will be solved.
It is a translation of Korean language into English into Google Translator. Thank you.
screw
09-14-2021, 06:02 PM
I have same jam J 7229 today, on km 950 with FS-532 finisher. I see that paper hit the black plastic on exit. To solve problem on quickly i cut that plastic. I will put new plastic but it works without50139
wjurls
09-16-2021, 03:32 PM
No need to replace the plastic. They will work fine with the end trimmed off. Konica upgraded this exit guide in later later revisions.
FixitYo
11-11-2021, 05:38 PM
Thank You .... this tip got me right to the problem, spot on!!
